raccoonreg
- Sep 8, 2010
- Canada
Hi,
I have done countless searches and read a lot here I want to thank you guys in advance for all your patience answering the same questions over and over again hopefully mine is slightly different.
Ok I have an old 16ā Harrison lathe, they came with a 3,5 and dual speed motor. Iām replacing the motor and installing a vfd for motor control and to update the old nasty wiring.
I have found a great deal on a new 5hp 200-240vac Baldor unit, great! Purchased. Searching for sutable motor now. First thought would be 5hp (bigger the better right) Now I have a 5hp RPC I run everything else in my shop no issues. My intentions are to run the vfd off single phase. After more though here are my questions. Mainly to avoid vfd motor derating , let me know opinion for best combo
5hp vfd and 5hp motor using single phase in (2.5hp net hp)
5hp vfd and 3hp motor using single phase in 2.9???? net hp??? not sure if this would make more power or not
5hp vfd and 5hp motor using rpc 3 phase??
Iām not going to running the lathe at max capacity so Iām looking for max energy efficiency and max hp. Not looking to do this twice so I had to ask. Thanks
