whateg0
- Mar 24, 2009
- Wichita, KS
I'll start by saying that I bought a cheap VFD off of ebay, but it seems to work aside from the lack of braking resistor capability. But it was long after I bought it before I was at the stage in the project to realize it, so it is what it is.
That aside, I am using this on a lathe with a 2 hp motor. I can set the speed fine from the control panel. When controlling it via the 0-5V input, I have some issues. There are settings for accel/decel rates, but those don't seem to apply to an external input, so changing the frequency rapidly results in an over-voltage or over-current condition depending on which way I go.
I am looking at alternatives, but I've not really found much information on whether this is typical behavior. If it is, then there's really no point in spending money on another VFD. (Ok, it would be good to have a braking resistor so I can stop the spindle a bit more quickly.) I have drawn up a conditioning circuit that should do well to prevent these errors in most circumstances, so replacing the VFD isn't a real requirement at this point. So, do other VFDs also depend on the control voltage rate of change being limited, or do they apply the accel/decel values to whatever is controlling them?
