I ended up with 3 of these motors, face mount, tapered shaft with keyed threaded ends any idea what they might be for? no luck when searching by part number...View attachment 205798View attachment 205799
Possible blower motors
That looks like laser engraved plate to me and in that case it is not from 1964With the V/hz data on them, and a frequency range, they are clearly intended for use with a VFD. But the numbers that look like a date (1-25-1964) would indicate, if they ARE a date, a very old application, and the 150W power level is tiny for most machinery or even blower applications. Possibly a tape drive motor, feed motor, could be a pump, blower, etc, Anything requiring only a low power, but variable speed. The shaft type may be a clue.
Unless someone recognizes the motor, probably no way to know for sure.
IEC80 standard is also most probably later invention (looks to be IEC80 B5 flange mount)
Normal 380v VFD is just about right for these @9000rpm, maybe that is a clue about normal operating rpm.
thanks for the help, still a bit of a mystery I guess. I thought the shaft style might tip someone off. Strange taper. Came out of the Invista cordura fiber plant in Chattanooga in a lot of odd parts crib stuff.
t
So the max voltage is called out by the frequency range and 2,5v/hz notation on the tag? .........(or is the v increase a result of the increasing hz)?
So the max voltage is called out by the frequency range and 2,5v/hz notation on the tag? My technical vfd knowledge is limited but I thought they varied frequency only, or do they all increase v w/hz (or is the v increase a result of the increasing hz)?
A VFD will vary the voltage and frequency together, in fact it MUST, because that's what determines the motor torque. The caveat however is that it can only DECREASE the voltage given to it. So if, in your machine design, you need a direct drive AC spindle motor with a speed higher than 3600RPM (the speed of a 2 pole motor), the only way to get that is to use a higher frequency than 60Hz. So for the VFD to be able to vary the frequency and voltage together at the correct ratio for the motor, you have to design the motor to accept a V/Hz ratio that fits your available power source. So in this case they obviously needed to run that (in 50Hz world) faster than 3000 RPM, so they designed the motor windings as a lower voltage, then allow the VFD to give it a higher voltage so that it can run it faster.Yes, and yes.
Well.. not the "only" way.. you can run it also with "reduced" voltage but your torque will suffer.A VFD will vary the voltage and frequency together, in fact it MUST, because that's what determines the motor torque. The caveat however is that it can only DECREASE the voltage given to it. So if, in your machine design, you need a direct drive AC spindle motor with a speed higher than 3600RPM (the speed of a 2 pole motor), the only way to get that is to use a higher frequency than 60Hz. So for the VFD to be able to vary the frequency and voltage together at the correct ratio for the motor, you have to design the motor to accept a V/Hz ratio that fits your available power source. So in this case they obviously needed to run that (in 50Hz world) faster than 3000 RPM, so they designed the motor windings as a lower voltage, then allow the VFD to give it a higher voltage so that it can run it faster.
Right...Well.. not the "only" way.. you can run it also with "reduced" voltage but your torque will suffer.
You can START it with reduced voltage, but running it that way continuously will cause the torque to drop by the SQUARE of the voltage change; i.e. at 1/2 voltage, the motor produces 1/4 of it's rated peak torque. So unless the load torque is reduced by that amount or more, it causes the motor to have higher slip and pull more current, generally leading to it burning up. Other than that, no problem...myself said:A VFD will vary the voltage and frequency together, in fact it MUST, because that's what determines the motor torque.
Notice
