ToughTool
Hot Rolled
- Apr 9, 2007
- Panama City, Florida 32401
When I bought my Bridgeport mill, the power supply wire to the machine mounted enclosure, with a 20 amp/3 phase CB (lockable) had the typical four wires, including the Green grounding wire and this Green wire was bonded to the machine casting. The wires to the E head motor (and the 2J head motor) however, were only 14/3 (White/Black/Green) with the Green connected to one of the phase windings in the E head motor and to a phase terminal in the enclosure. Also the switch on the 1/3 HP E head motor was a two pole, single throw switch, switching the other two phases to the other two motor windings. This switch looked original to the motor.
Question: Is this acceptable code or is it a violation. Does the grounding wire need to be brought all the way to the motor and bonded there? Can the green wire be used on anything other than for grounding in this manner? Joe
