projectnut
Stainless
- Mar 4, 2006
- Wisconsin
I acquired a Sheldon MW-56-P lathe earlier this year. It has a 2 hp, 220/440 volt, 3 phase motor. I have several other pieces of 3 phase equipment currently running on static converters. When I got the new lathe it came with a 15 hp rotary converter. The original intent was to use it to power the entire shop. However I will need to install another 100 amp sub panel to power the converter, and add several 3 phase circuits.
Given my current work load and outside responsibilities I don't have the time now to install a new sub panel and rewire the shop. I am considering a VFD as a solution to getting the machine up and running. I don't know anything about VFD's. I do know I need to generate 3 phase power, but that's about it. The lathe has a Worthington drive for speed changes so the VFD will not be used for this purpose.
Would a VFD be the proper way to power this lathe, or are there other more appropriate devices that could generate 3 phase? Also if a VFD is the proper choice how should amps it be sized. The motor plate says it will draw 7 amps at full load when wired for 220 volts.
