Up and running, but want to use the drum switch for fwd/off/rev as I've always done (control wiring, not power).
I'm a bit confused by the manual here; if you refer to page 4-32 (66 of 152 on the PDF) it refers to the "two wire control method Mode 1" which I think is what I want to use here...
https://www.tecowestinghouse.com/Manuals/L510_instruction_manual.pdf
But why do they call it "two wire"- don't I have to run a third wire (com) to the drum switch in addition to the other two?
In case I've got it all wrong- which is a distinct possibility- how would I connect the drum switch for this purpose?
Thanks in advance for the help.
