wolfenstien
- Oct 6, 2009
- Maine
Good evening all,
Seems like every time I try to go out and learn how to program my old yasnac lathes I run into problems running the machines. Latest problem is spindle drive randomly turns on and off.
Best guess so far is my incoming voltage is around 245+ phase to phase. (Running on a 30 HP american rotary converter).
What I'd like to do drop my voltage levels down around 220 if I can. I betcha that will make some of the mysteries I've been chasing go away.
Seems like i've got two options. 2 buck/boost transformers at each machine (6 total) or I can put 1 single phase transformer on the input to the rotary converter. I'm running that converter on 100 Amp breaker.
I get pretty confused looking at transformers though. Can someone enlighten me one what would work for what I want? Seems like there are lots of options. Is any 240v transformer going to do what I want? I'd love to buy one on the cheap/used etc, but I don't really want to go through iterations of ones that didn't fit the application. Been looking on craigslist, but not exactly sure what i need to be looking for.
Any suggestions?
Thanks in advance,
Joel
Any suggestions?
Thanks in advance,
Joel
