J_R_Thiele
Stainless
- Jan 22, 2003
- Columbia Missouri
I have a 1950's 5 hp motor for a shaper- and have run it on a 240 volt RPC- though not for hours on end. ( I am refurbishng the shaper)
From recent threads I know that 208-220v motors are considered OK on 240V supply- and that 208V and 200 V are not considered OK as it is over the 10% "rule".
208 V is 13.3% lower.
I have read one advantage of motors with higher voltage (440 for example) is that the wiring can be smaller and the motors smaller for the same HP output.
Based on the above I would assume a motor designed for 208 volts would have heavier guage wiring than one designed for 240V. This should give it greater amp carrying capacity- which it would need if it is loaded to the full 5 hp rated capacity.
I do not know what the difference would be in the windings between a motor designed for 208 V vs 240 volt.
I know the insulation needs to be appropriate for the voltage- but we are only looking at an additional 3.3% deviation from the 10" "rule".
Can someone explain just what makes the 208V motor on 240V unacceptable?
It seems to me that this would be OK if the insulation holds up. I would be more concerned with a 240V motor being fed 208V due to the potentially smaller wire in the windings, and increased heat build up.
JRT
JRT
