Charley Davidson
- Nov 8, 2011
- Murfreesboro, Tn.
Are 480 volt FVDs Alan Bradley desirable at all or even feasible? 480 input but will output 240. I can pick up a few of them but don't want to have to sit on them for years.
Beg to differ. They ARE 'protecting the user'. Forget the hobbyist working not at 'zero per hour' but actually subsidizing his effective (negative) hourly rate. Look at what the myriad of independent repair organizations charge. Higher than NEW prices in many cases. They HAVE to do. Goods made in high volume on automated PCB stuffing lines have near-zero labour content. Sitting down at a bench to analyze a board, find and then repair a fault, amortize test equipment, staff training investment, stocking of seldom-used spares - is WAY more costly.
Bill
If it is a REAL issue for your two-miles of production line? Stock more spares.
Or build yer own gear and stock spares AND components AND keep Engineers and technicians on payroll for that.
That's the sort of approach it takes to keep B-52 bombers airworthy and still capable of bringing extreme pee.
I'm sure it ain't cheap.
Bill
Two comments on using a 480V drive on a 240V motor . . .
If you can get a Load Reactor - that will help knock down the peak voltages the motor windings see and will extend the life of a marginal motor.
If you set the drive up using motor nameplate data . . . you are missing out on some performance. Set the motor up at 2x its synch speed minus the slip speed at 120Hz and rated current and you will find that you will get a lot more speed range out of the motor (as long as the bearings are in good shape).
Have fun!
Notice
