M. Moore
Titanium
- Jun 8, 2007
- Vancouver Island, B.C. Canada
What happens if you try and run a 220 volt motor with 575 volts?
And vice -versa? Can you run a 575 volt motor on 220 volts?
This would just be in a testing situation, not as a permanent setup.
There are some built in motors on my new cinnci mill and I think they are 220 volt but someone has marked them as 600 volt. The main motor for the horizontal spindle is clearly marked as 220 volt and runs just fine. The powered overarm motor has been over-stamped as 600 (220/440 underneath) but it runs fine on 220 volts.
The power feed motor on the knee appears to be 220 volt but someone has marked it in felt pen as 600, same thing for the coolant pump. My guess is that they are all 220/440 and some idiot got in there with a felt pen and a stamp. Not to mention the tag inside the electrical switch noting the incoming 600 and 220 volt wire sizes.
I would assume all motors to be the same voltage on a machine that looks to be in original condition and I just wanted to know if there is a downside to testing the motors with the different voltages.
Pics of the mill on the heavy iron forum
Michael
Michael
