coopertoolmaker
- Dec 24, 2008
- sc,usa
O.K. Hereis what I have.... An older H-A-S (steelman industries) rpc that has a tag that says, start H.P. 7 1/2, Total run H.P. 21, According to the company rep it has at least a 15 H.P. self starting motor. This thing puts out TOO much voltage on the 2-3 leg (286 volts with my 7 1/2 hp lathe running), 262 volts on the 1-3 leg and 241 volts on the 1-2 leg. It has (8) 60 mf capacitors in it connected across the 2-3 leg. The rep says just drop out 2 of the capacitors. I did that and the voltage balances out almost perfect, 238-245 volts across all three legs under load, but......the converter will not start all the time without all the capacitors...Question...Can I just hook up two of the capacitors in parrallel to a simple flip type switch That I can turn off once it starts up to speed ? Can I just wire the switch inline where the # 2 leg wire connects to one side of the 1st capacitor ? The #3 leg hooks to the other side of the capacitor. Thanks, Dale
