Century Repulsion Start-induction motor?
Community On The Web
Results 1 to 14 of 14
    Gunmetal is offline Plastic
    Mar 2006
    IN
    45
    Post
    Are there any "Century" guru's here that could help me get info or more knowledge on this motor.
    Specs are;
    Type:RS
    Frame:RS6B
    Amp:17.2-8.6
    HP:1 3/4
    SN:451499
    Phase:1
    Voltage:115 or 230ac
    On start up the brushes spark quite a bit, keep in mind I don't know much about motors didn't take those clases in school know I wish I had. As I understand this, does the body of this motor charge like a Cap, and do I need to bleed this off before opening it up? It runs very quite except the sparks, there is no ground wire on this so should I ground the frame of the motor or the mill/shaper? A cabnet next to it seemed to be energized on the metal frame, so I suspect that the cabnet was acting like an air coupled electronic device. I checked it out with a an ac device. I want to take it apart and clean it up, what oil should I use for the bearings?
    Robert Hager is offline Junior Member
    May 2006
    Adams Co.,PA
    Post
    Sparking probably OK. Brushes should lift when motor gets up to speed. These old motors were great-have very low start amps. They used tapered brushes. Bob
    Jraef's Avatar
    Jraef is offline Titanium
    Aug 2004
    San Ramon, CA USA
    2,139
    Post
    Century was bought by A.O. Smith Electric. They have tech support available for old Century motors last I checked.
    Mar 2006
    IN
    45
    Post
    Thanks for the info, so I can pull the front cover plate off to access the brushes and bearings? The hardware store near me is fairly old and they have an assortment of brushes. I should be able to find tapered ones there.
    I looked at the A.O. site but was unable to find any info on my motor is it something I will have to call them about?
    jim rozen is offline Diamond
    Feb 2004
    peekskill, NY
    22,120
    Post
    The century motors I have use end-on brushes
    (they bear on the face of the commutator) but
    I think they're not tapered.
    Most of those motors are highly re-buildable,
    but be careful as the brush holders may be
    made of an older material like hard rubber or
    fiber, and may be brittle.
    The motors are reversed by shifting the brushes
    so there will be an adjustment in there, check
    to see where it's seat before taking it apart.
    The brushes should lift when the motor comes to
    speed, there should be a centrifugal actuator
    similar to the switch in a capacitor start motor,
    but that lifts the brushes away from the
    commutator.
    Those motors have great starting torque, and I
    think they were in use during the days when
    electrolytic capacitors were rare. The pony
    motor in my phase converter is repulsion induction
    type.
    Jim
    Jraef's Avatar
    Aug 2004
    San Ramon, CA USA
    2,139
    Post
    Yes, you will ned to call them. They don't make these any more, but they should have drawings / manual available on them. I had to get info on one 4 or 5 years ago and they had it then.
    toolnut is offline Stainless
    Aug 2005
    Kingsport, TN
    1,189
    Post
    I had a RI motor for a while but do not remember the brand name. I had to reverse it for its new owner. I did not get the brushes rotated quite enough and the brushes sparked like mad.
    You might wish to check this. When you remove the plate covering the brush holder you should see a plate with both brushes mounted in it. this plate has slotted holes that allow you to rotate the brushes 45 degrees to reverse the motor. There should be an index mark on the motor frame and another on the moveable brush holder. These index marks must line up. If yours is not lined up but you can seee the marks and they are not far apart then I would suspect you have found the problem. There should be one index mark on the housing and two on the brush holder with the marks about 45 degrees apart.
    Like I said, I do not remember if my motor was a Century or not. I hope this helps.
    Mar 2006
    IN
    45
    Post
    There is an adjustment armature on the left that has 2 markings one on top has a "R" stamped on it and below that it is stamped "L". The pointer is just below the "L" marking.
    So if I get this right I should turn that adjustment a bit more down below where it is now to get the brushes closer. This will lessen the sparking right?
    reggie_obe is offline Titanium
    Jul 2004
    Reddington, N.J., U.S.A.
    3,125
    Post
    Try cleaning the commmutator. These motors have a fairly open frame and dust, grease and grime tend to settle on everything exposed. A wipe with alcohol might just do the trick.
    Mar 2006
    IN
    45
    Post
    Thanks for the input guys, I will see what I can do.
  11. #11
    chuckey is offline Stainless
    Jul 2005
    Wensleydale, UK
    1,167
    Post
    Gunmetal, please earth the motor frame, I wish for you to have a long and happy life. And while you are there, check all your machines have their metalwork/motors earthed - just incase a wire drops of.
    frank
  12. #12
    pipe organ paul is offline Plastic
    Mar 2013
    willington conn. USA
    I have rebuilt a lot of these motors I do have some infomation on them . These motors are used on pipe organ blowers I have seen them as far back as 1890's still doing there job if you still need help getting this one going let me know
  13. #13
    Newman109 is offline Titanium
    Sep 2006
    Sacramento County, California
    2,445
    I own a 1940's Parks 4" X 12" wood plane that I purchased well-used and which I rebuilt around 1973. It came with a then-new 2 hp Emerson reverse Induction motor, which is the size of a medium watermelon. . At the time that I bought the machine from a shop in Los Angeles I also bought a set of new brushes for spares.
    At the time, the dealer told me that I was wasting my money since, according to him, the brushes lift automatically at startup and typically don't get much wear. Turns out, he was right. I used the machine almost incessantly in the 1980's and I don't recall ever seeing any sparks when it operated. The motor always started instantly with no delay. As mentioned above, I would suspect that if it is sparking, it must need a good cleaning.
    I still have the new set of brushes in a drawer in my shop 40 years later.
  14. #14
    Mar 2013
    The sparking on these is due to the commutator bouncing the brushes,ether the comm is not true or high mica I usually cut a little as passable to true up the comm then cut the mica a little below the the segments not much the brushes need to run to get the motor to 75% full speed that can adjusted by the Governor spring
