Paid in full
- Oct 20, 2014
- Colorado usa
I have a clausing 1500 variable speed lathe I want to run on a vfd . I have read many threads on here but haven't found one that's simular to what I am doing , probably is one just haven't found it. So instead of hijacking someone's thread I'm starting my own .my lathe has very simple wiring just wires in to a forward, stop, reverse switch then to the motor not other electrical . The variable speed is completely hydrolic no electrical and the the brake lever is connected to a friction clutch that stops the spindle and the motor keeps turning . If I wire the vfd straight to the motor then wire the forward,stop,reverse switch to the vfd I can still use my hydrolic veriable speed control that's on the lathe and the brake lever without harming the vfd right? All the threads on here I've found have to do with variable speed and lever or foot brakes that are electric diffference being mine are not .
