So I am converting a band saw for single phase operation. I started looking at the schematic and it turns out the grinder motor as well as the main motor are 3 phase. Everything else can be ran on 110 or 220 single phase when I rewire it.
I do not believe I can make both of these work with one VFD, correct?
This complicates things a bit. I do not know the RPM of the grinder motor yet. I guess I could try to find a single phase motor with the right RPM and replace it and then just use the VFD on the main motor.
I would also consider just changing both motors and forget about the VFD, but the main motor does not have a spec plate on it that I could see. I am going to get my mirror in there and see if it is more hidden somewhere. Matching the RPM with a single phase motor could be a problem. Not sure.
I do not need to use the VFD for variable speed. The saw has mechanical variable speed already.
Any advice?
Schematics attached.
Any advice?
