Blue Chip Guy
- Oct 24, 2007
- Madison, AL
When a motor contains instructions for Delta and Wye connections which one should I use?
The motor in question is a 3ph coolant pump motor on my 15/50 Clausing/Colchester lathe. It had been connected Wye at it's former home (community college). I am powering the machine with a RPC. Main lathe drive motor is Wye and connected accordingly...RPC and Lathe run great. However, I removed the sump and pump to clean out the crud, and replace the hose. It's now time to put it back together.
Thanks!
Thanks!
