bandsawguy
- Nov 8, 2008
- Ontario, Canada
Can anyone help me I need to slow down a 120v radial arm saw. It is an older model with 6 brushes. The saw runs at 5500rpm and I need to go under 5000rpm. There is no name plate on the motor itself. The unit is just plugged into a 120v circuit which is protected by a 20amp breaker. I did see a controller on e-bay for 16.95 thay looked like it would fit the bill. It mentioned a 20amp capacity as well. Since this is a radial arm saw the motor is a intregal part of the saw and can't be replaced. We are attempting to use an abrasive wheel on the saw after our 10" saw died today. Found a 12" old Dewalt saw and thought it would be perfect but wasn't thinking the max rpm for a 12" abrasive wheel is lower then for the 10" we had. Also the new saw has a 1" arbor whereas the old 10" had a 5/8" so we can't just put a 10" wheel on the 12" saw.
