TonyS
- Jan 25, 2009
- California, USA
Not sure where this should be posted so I'll try here.
Due to having filled up a conduit, I plan to have a couple of infrequently used sanders share a 220v line with my air compressor. I would like the normal situation to be that the compressor is powered and allowed to start/stop as needed. If, however, I turn on one of the sanders, I would like power to the compressor to be interrupted; then when the sander is turned off, power to the compressor should be restored. IOW, instead of having to flip a DPDT or other control switch each time, I want the interrupt to occur automatically.
I have a little experience wiring up relays but haven't been able to figure out how it could be done that way. Does this require fancier control circuitry? If so, can it be bought for a reasonable price?
TIA,
Tony
TIA,
Tony
