kd1yt
Cast Iron
- Dec 6, 2013
- Vermont, USA
Let's say I have a chance to get an electrically driven hydraulic press on really appealing terms, but that the electric drive motor on it is vastly bigger than I need or want to accommodate (5HP) and the tonnage of the press is also more than I need.
Could I set a VFD with parameters that would assume full hp at 240V 60hz but then run the VFD at levels that are never any more than 1/5 speed/ frequency (and thus way down the v/f curve, so the lower voltage would also pull lower current) with a 1HP VFD (which I happen to already have several extra of)?
This would be for intermittent use, so the reduced cooling of the motor at lower RPM is not an issue to the degree that it would be for continuous use.
