Finally 'bout finished with Hisey-Wolf Grinder model S20...type 3LA...s/n# 218840. These grinders are really built to last....I am sad to be selling it (in a way). I used a Teco variable freq. drive as you can see in pics. If the video loads , or, you PM me for it, the first noise you hear is the 220 vac fan under motor mounting to keep VFD cool and dust from entering the mounting. The motor sits atop a 10 ga. plate, then atop two rectangular tubes(1" x 2") for height so air blows out sides with an alarming force...really should cool nicely(I cut a 4 in. hole in bottom of 1 in. plywood base to let air in mildly, besides the small risers on all base sides allow air in without a hard in-draft) I placed a blue filter panel inside base of pedestal.
The glass was replaced with same type(two pane with laminate between). Light bulb sockets are new style due to old ones cracked/broken. Light switches are new toggle(couldn't find 7330K2)with home made brackets.
The build/refurbish was fun.....need X axis power feed for my Bridgeport or I wouldn't sell this gem. Notice the motor is slightly diff. color than cover fixtures....painted motor as old school motor color....other grey has slight bluing in it and is my shop grey tone. Black on pedestal is Por 15. Other black is Hammerite . The rests are being sand blasted at this time will be in final "For Sale" pics. I wanted to mill off the uneven surfaces from yrs. of use
Now, on to the Dries & Krump finger brake debacle .
Thanks for viewing & comments along the way.
