Results 1 to 4 of 4
    Avispex is offline Plastic
    Jul 2012
    Utah
    Default Home Made RPC design- lost the thread
    A few weeks ago I did a google search for home made RPC designs. I read one thread, and I think it was here on PM, in which the fellow went to excruciating detail on his RPC. One feature that stood out was that in order to make brackets for his capacitors he sawed up some pipe and individually welded brackets on to them. The RPC had start capacitors because the builder did not want to mess with a pull string or an auxiliary starter motor.
    Is anybody familiar with this thread? If so, could you post a link to it. I wish I had bookmarked it at the time, but now I can't find it.
    Thanks!
    Shawn Ghormley is offline Stainless
    Jun 2007
    Amarillo, TX
    1,018
    Look in the Sticky above.
    Froneck is online now Hot Rolled
    Dec 2010
    Mifflintown, PA 17059
    671
    I'm not familiar with the thread but making brackets for the Cap. is easy. You can buy them too. Or are you just interested in making a RPC started with a Cap? I've made them for many of my friends. I don't agree with using additional capacitors both run and compensating. Be sure you use a contactor to connect the motor to the line wired to drop out if you loose power. A mechanical switch will cause your RPC motor to burn up and your other motors too if they are connected with a Mechanical switch when Power is returned after a power loss! You risk the chance of Fire too!
    Frank
    Jul 2012
    Utah
    I finally found th ethread I was looking for. It turns out it was in a completely different forum, but I still think it is very informative for any interested-
    3 Phase Rotary Converter - Shop Floor Talk
    Andy
