Pete Allan
- Mar 9, 2006
- Twin Cities, MN
Been lurking here for many years -- learned a lot. Any way I built a converter about a year ago and put a meter to it today. I have a 5 HP idler with 60 MF on each leg both connected to the mfged (B) leg. No load I have A-C 244 A-B 259 C-B 242 then With it running a 1 HP motor I have A-C 244 A-B 244 C-B 233. Looks like to me I need a sm. amount of MF added to th C-B leg am I right? Could someone give me a wild guess as roughly how much MF to add. Very shortly I will be adding a 7.5 HP motor to the load side but this will only run only seldom to never in a normal week so I am adding an additional 5 HP idler that can be kicked in when needed. I will be ordering the same caps for the add on idler so I thought I would ask questions now and order every thing at once.
