DebosDave
- Jun 17, 2009
- Bozeman, MT
Ok, I am planning on using this method to assemble a rotary phase converter, I already have the idler motor and the static phase converter, but I have a few questions if I can get help. Here is the schematic of how to hook up the RPC:
Questions:
1. With this method it shows using the same wires T1, T2, and T3 on my idler motor to input power from the static converter and to output to the load motor, my question is if I should use different wires to output from the motor? My idler motor has 9 wires in the box.
2. On the 3-pole switch, should I use a magnetic switch, or should I use a standard 3-pole switch?
3. It was mentioned in my first thread that I may want to balance the load using capacitors, where would they go in the mix? What type should I use and how do I test for balance? Is there a good resource where I can read more on balancing the phases?
4. Should I run wires right from my lathe to the idler motor, or should I run the idler motor to a circuit breaker, and then from the circuit to the lathe?
Thanks for any help you can give, I know I am new and have little understanding of terminology, but feel with the right guidance I should be able to hook this up without any problems.
Thanks!
Dave
Questions:
Thanks!
Dave
