rjibosh
Hot Rolled
- Jul 22, 2003
- Los Angeles
Hello,
Can anyone help me identify the leads from a GE motor? The name plate information is as follows:
GE
5KH25AC16A
1/12 HP
115V
1.6A
60 Cy
1 Ph
3450 RPM
Code T
SF 1.0
42 Frame
Cap GEJ213
It has four leads labeled T1, T2,T3,T4.
I assume two are for line and two are for a Capacitor. Would the capacitor spec be the GEJ213? And is it possible that number is still valid? Also, for this or any other motor is there a way to tell which leads go where using an ohmeter and would I damage the motor by connecting the capacitor to any two leads and line voltage to the other two?
Rick
lead
GE
5KH25AC16A
1/12 HP
115V
1.6A
60 Cy
1 Ph
3450 RPM
Code T
SF 1.0
42 Frame
Cap GEJ213
Rick
lead
