Great write up! I was really glad to see this, it is exactly the set up I plan on doing on my Bridgeport J-Head Mill and on my 16" SBL very soon. Currently I have been running my BP off of a bank of capacitors I set up to generate a third leg of power. I Love the infinite speed control idea on both of my machines.
I do have one concern though, My 16" SBL is a 1943 Quick change 6' model with the original Westinghouse 1.5 Hp / 3ph motor, it does run smooth and quiet. with that being said I am wondering if there is any danger to running a 21st Century VFD phase converter (Teco JNEV-201-H1) on a 70 year old Motor?
Any thoughts or advice would be greatly appreciated,
Joe
No problem at all. If it does die eventually, it is only a 20$ motor to replace.
Rob
 Originally Posted by Lost Pup
Square D Fusible Disconnect was purchased at Lowes for $15.00.
Do you have a part number for this? I really like your setup and the additional 115V outlets after the disconnect.
EDIT: I just seen that your using the JNEV-101-H1 (115V single phase in), i'm using the JNEV-201-H1 (230V single phase in) is this disconnect rated for 230V? I'd look myself but I don't have a model number. Lowe's is right up the road so this would save me some time.
Here you go
Square D 30-Amp Fusible Metallic Disconnect
Item #: 92606 | Model #: L211N $14.12
120/240 vac
Metal Indoor Enclosure
Horsepower rated 3 HP @ 240 vac
Neutral bar included
Lowes.com
I am installing....programing my TECO JNEV-201-H1, I also have the remote keypad to go along with it. I have the drive its self running ok but I cant get the remote keypad to control anything. THe remote keypad has power and dashes on the display. I have tried several combos of programing in the "F" Menus to no avail.
Wondering if anyone around here has any experience with this drive and / or the setup / programing of the unit to get the remote keypad to control the unit?
Joe
- You may not post replies
- You may not edit your posts
Forum Rules
