fultorn
- Apr 17, 2014
- Montgomery, AL
on a old kitamura cnc machine it has a motor starter relay with a Allen Bradley thermal overload relay that is connected to a oil pump that lubes the gears inside the head.
upon looking at the normally closed contacts on the overload relay. it had 100 volts on one side and nothing coming out the other. showing that it was tripped.
i pressed the reset button and the contacts on the overload relay closed again like they should be and the motor starter contractor pulled in,..
but the oil pump still didnt start up.upon checking the phases voltage before and after the overload relay.
i had 88 volts on two phases and 110 volts on one phase coming out of the contractor going into the overload relay.
on the other side of the overload relay. i had 110 volts on the same leg. but only around 2 volts and the other two. is this a bad overload relay?
i took it off of the contractor and checked for continuity across the relay and 1 phase is closed while the other two are open.
i think this is not normal just hope someone can confirm it. the other ones on the machine i checked and they are all closed on all three legs.
could my pump be killing the relay or is this something normal to happen over time?
