http://www.specotech.com/index.php/products/video/cameras/analog?format=raw&task=download&fid=55
The video cam inside the housing has only 3 wires, red, black and yellow. What I need to know is the yellow wire for absolute sure the signal wire ? Besides the color standards, internally the red and black wires double up such that half go the the LED lights and half go to the camera board. The yellow wire exits the camera board only.
The reason I want to know this is I want to connect a separate 12 volt source to the 12 volt camera input and then connect the signal wire to a rather expensive marine multifunction screen to see if the signal wiring is still connected at that point. But it might be rather problematic if I fed 12 volts into what is mean to receive signal info only.
I called Specotech but they won't talk to anyone about things like this unless you have an "industry professional" pin number !
