Engine Room Artificer
Hot Rolled
- Feb 28, 2007
- Gosport Hampshire UK
OT as not machne tool related.
I work on a boat which has a recently installed Air-con set up with 4 identical compressors which cut in and out as heat load fluctuates fed from a 400V 3phase supply via 4 separate inverters.
Other items of equipment (watertight sliding doors) fed from the same supply each have a phase rotation sensor relay which energises an an exceptionally annoying alarm
It seems that when 3 compressors are running, the supply is altered sufficiently for the alarms to be energised.
I remember (vaguely) that motors on their own draw an inductive load causing the power factor to lag, do inverters create a different characeristic (ie reactive or capacitive) which might be creating the alteration to the supply. I have tried measuring voltage drop but can see none.
The sensor in question is a schneider RM4TG which unfortunately has no adjustment to it's settings and it seems it is a bit too sensitive. If I am armed with what causes the problem, I can start looking for alternatives or perhaps a smoothing circuit or some form of time delay.
Thanks for any light you can shed.
