Results 1 to 5 of 5
    todd goff is offline Hot Rolled
    Feb 2007
    south carolina
    615
    Default Phase converter to run plasma cutter
    I have a dilemma here and was wondering if I could get some advice from everyone. The problem is that I have a large plasma cutter but I don't have a big enough phase converter to run it. My phase converter is a 15 horse which I think off the top of my head is about 50 amps???? The plasma cutter would use 125 amps 220 or 65 amps 440 volt. I was wondering if I could possibly build a 220 volt converter using an idler motor??? Also, I was wondering if anyone has ever built a phase converter that generated 440 volts, if it is possible or am I plain nuts?
    Shawn Ghormley is online now Stainless
    Jun 2007
    Amarillo, TX
    1,018
    Sounds like you need a transformer to go to 480v and cut the amps in half, then use a large idler for the converter @ 440/480.
    Heavey Metal is online now Stainless
    May 2011
    1,622
    What model is your plasma cutter?
    Feb 2007
    south carolina
    615
    I am not real sure right off; it is a Linde and will cut up to 2" thick. I am at work right now but will let you know tomorrow.
    ford 460 is offline Aluminum
    Dec 2011
    bis nd
    155
    I run my 300amp linde wire feed on a 15hp idler witch is to small on paper but im not welding at 300amp and drawing max power At 150amps witch is have the out put I should only be pulling about half the amp from the conveter or so you should be able to run it just not to full capicity
