DaveKamp
Titanium
- Oct 3, 2004
- LeClaire, Ia
Hi All-
For those who build their own RPC, the frequent choice for start-capacitor control is the STEVECO potential relay.
Because it's a for-purpose device, it is often challenged to be used starting some frequently much-larger-than-intended loads in our rotary phase converters. Because of the way they're internally wired, it's not a simple task to connect them to a repeating contactor to get higher current capacity.
I was looking through the documentation on other products and stumbled upon this:
Motor Starters - Universal Motor Starting Relays | HVACR Industry Leader of Electronic Controls | ICM Controls
I immediately realized that it may be a viable alternative. The wiring sheets diagram it in much the same way as the STEVECO (that's the type of product it's intended to replace), but I believe they may have made it in such a way that it could be utilized for start-cap control in a typical Fitch Williams or similar setup.
I have not tried one, but I have used other ICM products- delay timers and replacement furnace controllers, and I'm extremely pleased with the results... IMO, they've got some fine products going.
