Brad Amos
- Jan 4, 2009
- Cambridge UK
I have acquired a superb Colchester Master Mk 1 lathe and would appreciate any advice on setting it up in my home garage in the UK. Tony Griffiths (Lathes UK) has advised me to use a Siemens Sinamics G110 inverter to convert my 240v single phase supply to 230v 3-phase, and I have wired an appropriate Siemens 3 HP motor in the delta configuration. This combo runs smoothly and I am really impressed with the way I can control the RPM with a pot. Am I correct in thinking that I should not even bother to try the original starter switchgear, since it will almost certainly have a 415v coil, and I am better off using the ON/OFF digital control on the inverter, which will give me a nice ramp-up and ramp-down operation? I can't think of a neat way of retaining the existing switches, so I will probably replace them with a something along the lines of a plunger which closes a microswitch when pulled out but interrupts the 24v control circuit when pushed in, so it will behave just like the emergency switch during turnoff. I am not bothered about using the suds pump, which is the only other item requiring power, apart from lights.
Also does anyone have for sale a fixed or travelling steady for this lathe? I do a lot of optical work and will need to turn longish tubes.
