Results 1 to 10 of 10
    kngkong is offline Aluminum
    Oct 2009
    Wellington, New Zealand
    211
    Default Reset Teco 7300cv vfd? Stuck in ES
    Does anyone know if there is a way to reset my vfd to factory default settings? While hooking up my emergency stop button I remapped the reset parameter. The vfd got a emergency stop signal but since I remapped the reset parameter I'm unable to clear the ES fault.
    Any info on either a way to clear the ES fault or restore factory settings would be highly appreciated as I can't run my machine. Cheers.
    abarnsley is offline Titanium
    Mar 2005
    Palmer, Alaska
    2,985
    Man I never mess with things I do not know well...
    No need to remap anything to hook up an ES.. A parameter change only..
    Is is something simple like 15-6 reset mode on page 4-20 here???
    http://www.teco.co.uk/drivemanuals/7...nglish)V12.pdf
    Or 2-07 on page 4-26.
    It is almost always a simple thing, not properly input...
    Surely a TECO whiz, or a call to tech support will get you straight quickly...
    Edit You did power down the VFD, and power it back up of course??
    Oct 2009
    211
    Yeah. Well ummm. I found the multifunction inputs really confusing to figure out, or not figure out in my case. I thought I needed to assign commands to the S terminals so I set 5-05 to 0007 and 5-06 to 0029. Totally user error understanding the manual. So I basically removed the reset command I guess.
    Yeah I tried powering down the unit for about 10 minutes and would still come up with the fault when powering up again.
    Oct 2009
    211
    Thanks abarnsley, I see the reset parameter you mention on page 4-20. Unfortunately i can't input any commands while it has the ES fault. I could fix the parameters I changed if I could clear the ES fault it's in.
    Oct 2009
    211
    I think I also went wrong by running S5 to the E stop button and S6 coming back from the button. Should I have been running the 24v com to it and then to where?
    I've since removed the Estop switch. Maybe if I reconnected it properly it would clear the fault.
    Oct 2009
    211
    Just got off the phone with Teco tech support very friendly and gave me a solution. Will be able to try it in a couple hours.
    atomarc is online now Titanium
    Mar 2009
    Eureka, CA
    2,250
    Quote Originally Posted by abarnsley View Post
    How would a person learn to know something well unless he did 'mess with it'?
    Stuart
    Mar 2005
    Palmer, Alaska
    2,985
    Mess with only 1 advanced parameter change per test.
    It is so tempting to make a bunch of changes at a time. Which make troubleshooting a mess
    Oct 2009
    211
    I've been on with tech support for the past two days and they're pretty much stumped as to why it's locked up. They don't feel it was something I did. Working on a solution....
    Oct 2009
    211
    Quote Originally Posted by kngkong View Post
    That's for the replies. I did end up getting a new drive and everything is working as it should now. No explanation yet. Cheers.
