imported_eric_h
- Mar 14, 2007
- Atlanta, GA
Quick question, I purchased and American Rotary RPC panel for a 5hp idler motor. I hooked everything up and fired the RPC up. It is not under any load at this time. After about 30 minutes of running the idler motor seems to be running at a very,very warm temp. You won't burn your hand if you touch it but the temp. seems to be running higher that it should. The wiring is sized right and it isn't warm at all. The current temp is about 40 degrees so it isn't warm in the garage. The bearings in the motor are new and I gave the motor a good cleaning so it spins freely.
Any thoughts?
E
Any thoughts?
E
