The VFD stands for Variable Freq Drive. You will not be varying the frequency. Seems like a waste
of VFD if you spend a lot. But it will be quiet. The compressor will make a deal of noise when charging
so a quiet VFD probably is not going to make much difference.
A RPC built by you will be less expensive. The RPC will only be on when charging the tank. The
RPC will be more reliable.
A VFD could be used to decrease the RPM of the motor allowing you to run the compressor more quietly, which could be a huge plus.
The tank would take longer to charge. In most situations the air supply demand will keep that
motor running and running. Plus not. Quiet is not the issue, the frequency of the pump noise is what
will change. The tradeoff is faster speed and tank charge, or slow speed and longer tank charge with
a low frequency pump sound with longer duration. Who would want a starved air supply. Probably if
have infrequent use and like a zen setting in the shop.
Air demand in a home shop situation for a 15 hp air compressor will not keep the unit "running and running" unless there is something special going on. and in that case, bump the VFD frequency up to 70hz and enjoy the rapid recovery! ;-)
ps, I absolutely enjoy the rhythmic pulse of a slow speed air compressor. If not for the VFD on my own unit, I would have opted for single phase motor with an oversized compressor pulley. Just to slow things down.
Notice
