Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
A friend of mine has and old Herman Nelson hot water heater (radiator type unit that looks like a propane heating unit) with a Reliance 1/6 HP 3 phase 1725 RPM fan motor that's burned out. May have lost a phase because no phase protection on the controls and 120VAC contactor coil from another source.
Motor is old and is 56G frame. It's resilient mount outer ring and rubber there but not used. It's mounted via 4 stubby U type bracket attached with the 4 studs that connect the 2 end plates to the field winding housing. Each bracket is the same width as the distance between the front and back end plates where the studs are with a single nut on each side holding it in place. (no inner nuts as the stud has to be removed to install the bracket)
What I need to find is a motor that has the same OD and the 56 frame with the same end to end distance (or shorter) at the stud locations and same bolt circle. (a long screw will work)
I have a 1/4 HP single phase 145 frame motor on an older Buffalo bench drill press that has almost the same front to back distance about 5/16" shorter (will work spacer can be made) Has the same bolt circle and OD.
Anyone have any idea how to find a motor that will fit? NEMA frame charts don't give the needed info nor can I find information on 56G. I called a Reliance dealer but he can't cross the model number found on the nameplate. 145 frame will probably work but I can't find any low HP 145 frame motors, all I find is 145T that is too big!
Frank
Frank
