All right so went out and bought a Lagun 10 x 50 Vertical Mill (3 HP motor 9 amp) and an Acer 17 x 40" lathe (has a 7 1/2 hp motor 20 amp) for my garage machine shop and a 10 HP rotary phase converter from Phoenix phase converters. I had it all wired up with breakers and everything and it worked great until the other night I went to start up my lathe at 1800 rpm. It started to wind up and drew enough power to dim all the lights in the whole house when all the sudden it just shut off. The phase converter will still run my mill, but not my lathe. I tested it with a multi-meter and still have power going into my lathe and the fuses still good in both the lathe and breakers according to my multi-meter. I'm no electrician and am looking for some help here.
