hurst01
- Nov 28, 2008
- Jeffersonville, IN
I purchased a couple of DoAll vertical milling machines a couple of years back. I was really impressed with one of them as far as appearance goes, but after transporting them 300 miles found that the best looking one had been steam cleaned and put in storage. Spindle bearings locked up and bad motor bearings. I broke down and rebuilt the machine head and it sure sounds good.
Now for the problem. It was 460 Volt. I rewired it for 240 and hooked it to my RPC. It has an Allen Bradley Start/Stop switch mounted on the rear of the machine. I can press the start button before starting my RPC button before. It clicks and stays in. After starting the milling machine, it will run for about 3 minutes and the AB Start/Stop switch kicks out and has a moderately loud buzzing sound. It will not reset unless I turn off the RPC
The only thing I can think of is since the mill was 460 Volt, maybe the Start/Stop switch needs to be rewired, or perhaps it is for 460 Volt and can't be used? My other DoAll milling machine does not have a separate Start/Stop switch and works very well just by starting the RPC and turning the milling machine on. This is not to be confused with the Forward/Reverse switch on the head of the milling machines.
Any help would be most appreciated.
Ed
Ed
