Don_Hartman
Hot Rolled
- Jun 1, 2008
- Cincinnati,Ohio
Does anybody have any experience with Teco/Westinghouse AC drive on there small shop equipment.I am looking at the EV and or the FM50 models.This will be for a 1/2 hp motor on 115v.I was looking at these models because I want the remote panel option.Other factor is cost for the remote panel option.Also the same exact model inverter will be purchased for another project down the road.Is there any benifit of choosign a larger model over a smaller.ie selecting a 1hp when only needing a 1/2 hp model at this time.Also would the 1hp model work on a 15 amp circuit?I know my 1 hp single phase motor sometime trips the breaker.I Am in a rental condo with a detached garage.Running a higher amperage circuit to the garage would not be aloud and therfore is out of the question.Would the 1hp model work with only 15 amps?
Exact models I am looking at are.
FM50-1P5-C(1/2hp)
FM50-101-C(1hp)
JNEV-1P5-H1(1/2hp)
The one motor I have is a brand new Baldor CWDM3538,FWIW this motor has has the Inverter Spike Resistant magnet wire.
Don
FM50-1P5-C(1/2hp)
FM50-101-C(1hp)
JNEV-1P5-H1(1/2hp)
Don
