Beezer
- Feb 12, 2009
- ON, Canada
I have been debating which route to go with to power my Bridgeport Series 1 2-HP mill, with 2J VariSpeed head at home off a single phase.(Motor is wired for 230 Volts) Either use a RPC or VFD. I think I am leaning towards using a VFD and I think I have found a model that would meet my needs but would like some input and even less expensive alternatives.
It is a TECO MA7200 AC Drive, 2 HP, 230V 1 / 3 PH Input, 230V 3 PH Output, 6.4FLA, NEMA 1
http://www.factorymation.com/s.nl/it.A/id.218/.f
My VariSpeed head is in really good condition so I would be using it to control my spindle RPMs and not the VFD. I also would like to use the mills original drum switch for forward and reverse. I have been told that needs to be wired into the VFD low voltage side to work.
I may consider going with the Nema 4 enclosed drive to keep dust out of it since I do some woodworking in the same garage. Just need to consider the extra cost to see if I can justify it.
Any input appreciated.
