VFD drive a PSC motor?
Community On The Web
Results 1 to 4 of 4
    86turbodsl is offline Aluminum
    Aug 2004
    Albion, MI, USA
    52
    Default VFD drive a PSC motor?
    Like the title says, can I drive a low power PSC motor with a VFD, assuming I remove the start cap? I realize the start winding is probably 90 degrees out of phase rather than 120, but will it work? It's for low cost speed control of a PSC circulator pump. I can get the VFD's for about $30 or so. A true variable speed PSC control is MUCH more expensive.
    Jraef's Avatar
    Jraef is offline Titanium
    Aug 2004
    San Ramon, CA USA
    2,135
    Quote Originally Posted by 86turbodsl View Post
    PCS implies it is a 1 phase motor. You cannot run a 1 phase motor from a 3 phase VFD, the VFD will not allow it and trip on output current imbalance (although a few may allow you to defeat that, they won't be the $30 variety).
    There ARE however a few 1 phase VFDs that are designed to run 1 phase motors; Bardac / Sprint and Anacon both sell a VFD made by a company called Invertek (from the UK) that is a nice drive. They ONLY work on PSC and Shaded Pole 1 phase motors, no modification of the motor is necessary. But the VFD is going to cost you more than $30.
    Where are you finding a $30 VFD anyway? FleaBay? Be wary of cheap used VFDs, they can be junk.
    JST's Avatar
    JST
    JST is online now Diamond
    Jun 2001
    St Louis
    12,994
    Quote Originally Posted by Jraef View Post
    Every single one I have run into has been junk.....
    Aug 2004
    Albion, MI, USA
    52
    yes, you are correct, 1 phase motor, 2 windings, 90 degrees phase angle. The VFD's I've been seeing are on ebay, but lately, I was thinking the automation direct GS1's are a better deal, as they work on modbus and my plc can directly control them. Now I just need a circulator with a 3 phase motor....
