Im just trying to figure out how I would wire up all my machines using a rotary phase converter. Is there just one wire coming out of the RPC and branch off to all the machines and have a seperate breaker at each machine,or are there multiple wires coming off of the RPC. Now when I say one wire im actually meaning one wire with 3 conductors in it.
Any advice on this would be appreciated.
Thanks Mike
Hi Mike,
I ran 1Ph 240V through a 30A breaker, into a 3Ph disconnect, (100A!) out to a 10Hp idler, (23A, pony start) and from the same lugs, (with the idler) 3Ph out to a #6 (had the #6 conductors on hand) circuit that runs completely around my shop, with junction boxes, (deep 4" X 4") every several feet.
I wired up proper ampacity, (or greater) 4 prong, 3Ph receptacles in the few JB's that I had machines for and just pulled a loop in the rest. Have since cut a couple of these loops to wire receptacles for new machines. Any greater protection, (than the 30A feed) I feel necessary, is provided at the individual machines, making it very simple to build.
With the #6 conductors and the 100A disconnect on hand, a future upgrade will be very easy.
The alternate of course is RPC into a breaker panel with as many separate runs as you have machines, the way to go in a commercial setting but bigger conduit and lotsa' wire, though some of it can be light gage.
Being in a private, one man shop, I took the quick easy but still safe way.
The plug/receptacles serve as disconnects for all but my hard wired 17" lathe but the 100A disconnect is literally 2' from the lathes tail stock.
Bob
