Advice on building an exterior door for house in extreme cold environment - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21
    Sep 2002
    gloucester ma
    1,615
    48
    947
    Quote Originally Posted by Bill D View Post
    Btu's for how long?
    Bill D
    per hour as all such measurements are done
    if you are going after my shorthand, is spelling next?
  2. #22
    Sep 2002
    gloucester ma
    1,615
    48
    947
    As I think on it, air sealing is really improtant at those temps. a small leak will probably freeze the moisture coming out of the house so quickly it could freeze the door shut
    Cardinal makes some multiple coating triple pane that is R6 center of glass, I used some of this to make some custom sliders for my house and the inner pane measures something in the mid/low 60s when it is below zero out, ~69 degrees inside. This is not the kind of temps you are dealing with, but to give you frame of reference
    LoĒ Performance Statistics
    bottom of the page they get up to u.11, R9. I couldn't get them to build them that thick back 7 years ago.
  3. #23
    Oct 2014
    Maine
    548
    7
    273
    Quote Originally Posted by SteveBausch View Post
    The client will eventually reconsider not having an airlock/mud room.
    Despite being a great idea, most houses don't have arctic entries. Mud room/entryway yes, but not a proper arctic entry. Even when people remodel and add an entryway, it is usually connected to the living area. If you have a two car garage, you're probably going through the garage most of the time anyway, which acts as a sort of arctic entry.
    The only place I've seen them used consistently is in the bush. You don't tend to see big garages, and people don't drive cars as much.
  4. #24
    Apr 2004
    Modesto, CA USA
    5,420
    765
    I did not know the BTU's is always per hour. Thanks for the info. For AC it is tons per day or BTU's which I guess is per hour also. On the nameplates I have seen it just says BTUs with no mention of time.
    Bill D
  5. #25
    Mar 2017
    CHINA
    1,982
    913
    Quote Originally Posted by richard newman View Post
    Gotta believe that the Alaskans (and Siberians, Tibetans, Tiera del Feugans, etc) have this figured out by now. Field trip!!!
    Buncha cheechakos. Real Alaskans just call another sled dog in and cuddle up
