Kirol
- Aug 16, 2012
- Oregon, United States
Short summary: Need to rip UHMW ranging from 2.0mm to 11.0mm thick (not flat) and about 154cm long. Both edges of the UHMW must be 90•+/-.5•, and most importantly the edges of the UHMW must be completely smooth and free of saw marks.
About the process: We work with UHMW material that is about 13mm thick, and with lengths ranging from 130cm to 160cm. We use either a CNC router or planer to machine a "thickness profile" into the material. This thickness will always be 2.0mm on either end of the material and in the center be in the range of 7.0-11.0mm thick.
After machining, we take the material to a table saw with power feeder to rip into 12mm wide pieces. Down the line, this UHMW will be bonded on 3 out of 4 sides - including one of the saw cut sides. Table saw cut quality is crucial and anything with blade marks showing will have to be sanded on a belt sander.
Since upgrading our table saw, we have not been able to achieve smooth quality.
Smooth cut quality sides are 90•+/-.5•, surface texture is free of saw marks, is smooth, and has a matte or slight melt appearance.
We have achieved smooth cut quality before: Our current saw, and the saw we are having trouble with is a Powermatic 66 from 1978. Our previous saw, a Grizzly 715 did achieve good cut quality but had some other inherent problems and had to go. Although we were cutting smooth with this saw, we were going through about a belt a month and would sometimes have bind ups that would trip the breaker on the motor starter. Even when running well you could hear the material bogging the motor down. The other factor that turned us off was that we could not move the trunions enough to achieve perfect miter and blade parallelism.
The main reason for the upgrade was to have a more powerful saw. The Grizzly has a 2HP motor and power requirements limit us to 3HP at max. We decided to buy a 3HP Powermatic 66. I have heard nothing but good reviews of the PM66 and we were able to trade our saw + some cash for the PM66.
What could go wrong? I mean the only practical difference in our process is the PM66 has a slighty faster arbor RPM, 4000RPM on the PM66 and 3850RPM on the Grizzly. I did mention the Grizzly was bogging down so the actual arbor RPM must have been slower.
What we have tried:
What is currently (kind of) working:
We are achieving a very good cut quality with our blade, Freud LU94M010 10", 80T, -3• hook, carbide tipped, triple chip grind, .110" kerf installed backwards. We are running this blade backwards with our power feeder set to the slowest speed, 13FPM. The cut quality is actually very good. The surface is very smooth and never requires touch up. The angle is always within .1• of 90•. We believe that the blades is melting its way through the material and the triple chip grind is actually centering the blade rather than let it wobble as it catches going forward.
Running with the blade backwards does have its problems. The most troubling is the stress this is putting on the motor. The motor is getting very warm after ripping and sometimes bogs down - still not as much as the Grizzly bogged down. We are getting about 25% of previous tool life. Before we were getting about 1200 rips per blade sharpening now we are down to about 300 rips.
What we are thinking about trying:
Does anyone have any suggestions?
I'm open to any suggestions to try. Time is very valuable at the moment and money is tight. Any advice or insight is greatly appreciated.
What we have tried:
- Same set up that worked on Grizzly - ie same blade, same blade height, same feed rate, etc... Saw sounded smooth and quiet like cutting better. Cut quality is a little... rough. Our saw vendor and re-sharpener believes the Triple Chip Grind (TCG) (meaning that the carbide cutters have 3 different grinds) and that the UHMW is causing blade wobble as it hits each different tooth in succession. More on this below in "What is currently (kind of) working:"
- Slower feed rates, faster feed rates. We tried every feed rate possible with our power feeder and then bought more gears to try more feed rates.
- Different blades - Every "plastic" blade that worked in the past, carbide tipped wood blades, carbide tipped plastic blades for a circular saw, HSS high tooth count blade meant for cutting plywood. We tried all these blades forwards and backwards. The best cut quality was achieved using the plastic cutting blades backwards.
- Blade stiffeners - We now have a blade stiffener on both sides of the blade.
- Backwards feed - with the blade installed both backwards and forwards I set the power feeder to reverse and fed the UHMW through. This cut quality was not any better than feeding the correct way.
- Blade vendor wants to use HSS and make a blade with no hook angle, a "v blade" that has no forwards or backwards, similar to a cold cut saw blade. We could try this for the cost of materials and arbor bushing.
- Slowing down our table saw arbor RPM either through different motor and arbor pulleys or controlling the motor speed. Our motor is 3HP, 1phase. I am currently researching VFD with single phase output. I know that at full speed our Grizzly saw was spinning slower at the arbor and will be even slower when bogging down. With speed control we could slow the motor down to what the Grizzly bog down speed would have been. We could also start thinking about adjusting with chip load in mind.
- Use 2 of our Freud blades and grind one side of the teeth flush to the plate and grind the teeth flat to the plate on the other blade so that can "mate" into one thicker blade. Getting a quality cut is more important to us here than the saw kerf, my theory is that the two together will be less likely to wobble..
- "side" one of our Freud blades - grind the carbide teeth down to thickness of blade. Blade vendor is advising us against this, believing that the blade will quickly over heat.
