I need suggestions on the diameter of the sized hole that I should drill in the ash wood for gluing in my cleats. I made some coupling nuts using a 0-80 thread size with a brass dowel that has a .125" diameter.
Click on the images for a better illustration of my question.
Do I make my hole for gluing the brass coupling nuts a tight fit or do I make it a sloppy/loose fit so the glue can do take a good hold. These need to be glued good due to the fact that these are going on an ash flag pole that's going on a boat. So this will actually be a working flag in windy conditions.
Thank you
Thank you
