SBAER
Hot Rolled
- Aug 21, 2006
- Kitchener, on canada
I have a 12" Poitras thickness planer with a 5hp motor, a three knife 4" diameter cutter head and a serrated steel upper infeed roller. The only way I can get rid of the shallow scallop marks ( they seem to be at the exact pitch of the serrations on the infeed roller)is to roll electrical tape around the infeed roller. The marks are there even when a 1/8" cut is taken, scallops are worse in hard wood than in pine.
I have sharp knives and they are set within 0.002" to the bottom of the infeed table, I have tried backing off the tension on the infeed roller springs.
Is this something left to try other than replacing the serrated roller with a rubber one?
