How long does it take to change over?
My shop isn't commercial, so time isn't of the essence, but I prefer not to waste it. I make some furniture and other things for the house for fun and we build and repair some stuff for the farm and probably use the jointer a lot more than the planer. Do you have the mortising attachment? If so, what do you think of it?
About half a minute or less- 15 seconds probably.
But...
The time to change over is not really the issue- a process break is a process break.
I suppose I have accommodated my work flow slightly to having to make the function shift by doing batches of thicknessing work or joining work so I am not switching machine all the time.
For me this is fine but some might be driven to distraction by the need to change over machine- the "oh crap, I planed the board and forgot to dress the edge so now have to flop the tables down to join before I can rip...
I am very happy with the machine and don't find I sweat the change overs but then again my shop is very tight so the convertible is a good 'fit' for me..
In my shop the MiniMax lives in joiner mode.
I would guess that I tend to dimension stock on BS or TS more than I would if I had a planer ready to fire at all times.
A big shop where waiting in line to use a multifunction machines means you are paying guys to stand around- no good.
A one man shop where you can only use one machine at a time- really depends on how you like to work. Two machines probably win if you have the room..
Did I say the Tersa head is killer?- I would want that head on any machine I owned..
Mortising- I wanted one initially but now would not bother- the attachment is right in the way for running boards though machine so I think (never had one though... ) that I would never have it mounted and not use it so much.
Besides- my shop is too tight & I could not work ends of sticks to attachment anyways.
The Domino is a killer machine- functional, adaptable, simple to use, fast.
Depends on shop though- not having stops for stock and clamping is a real limit to production.
I do well with a portable but- the great strength and weakness of the Domino is that it is portable..
I do M&T work maybe a few times a month- if done every day fixturing would be required for stock.
If you are doing lots of this work- having the fixture clamped to the joiner or dragged off shelf would be a PITA
Sooo.... I think the mortising attachment is a not so good fit for my use and not a good fit for high production use either..
If you have the room and need- buy a good quality stand alone machine or rock and roll with the Domino.
Oh- one bit difference with convertibles:
There are no stock rollers on top of machine so boards are not quickly tossed back to run again- I do the carry board back to start thing.
Of course I am usually running a number of boards so it is more like- carry boards and stack on each side, adjust adjust for another cut- repeat.
