Grizzlybagworks
- May 8, 2016
Need Help finishing my 1965 Delta 17" Drill Press Rebuild/Restoration (Vid Attached)
I'm almost finished with my 17" drill press restoration but have run into a couple challenging problems. I'll just cut straight to it.
Problem #1: The upper bearing on the upper spindle shaft was totally seized and ended up spinning on the shaft. The shaft is 25mm but is currently worn down to 24.4mm. The location is pretty much dead center on the shaft.
Possible Solutions:
1. JB Weld the worn area and turn that down to size. (Safest/Easiest but longevity is questionable)
2. TIG Braze w/ Silicon Bronze and turn that to size (Possible Distortion ??)
3. Braze w/ Acetylene (Possible Distortion?)
Problem #2: The shoulder on the lower motor pulley also had a bearing spin and wear it down. The pulley appears to be cast aluminum.
Possible Solutions:
1. Mount the pulley on the shaft, mount it between centers and turn down the shoulder. Then press on a sleeve and turn to size (what material should I use?)
2. Build up Weld Bead around the shoulder and turn it down to size (Possible Distortion or problems welding on the cast aluminum)
3. JB Weld Build up/Turning?
I realize the ideal fix for the spindle is to have it done professionally (spray weld or hard chroming) but I just can't justify the cost.
ANy input would be appreciated. Thanks guys!!!
Possible Solutions:
Possible Solutions:
