Need help replacing bearings in old two head shaper
turkeybuzzard
Feb 4, 2011
North MS
I bought an old two head shaper several years ago that needed new bearings. I have come to the point that I need it but am having trouble figuring out how the spindle comes out. I will post some pictures and maybe someone can give me some pointers. Will gladly get more pictures and information if needed. This machine was not well cared for, I bought it at an auction in TN. Thanks for any help.
First I would pull the actual spindle from the whole assembly. Save you the risk of bending it. Then I would pull the whole yoke assembly from the machine and work on it on a bench, much easier to deal with. Once you get it out and the dust covers off the bearings it should be a bit more obvious what you need to do to pull everything apart.
Dan
Dan
That's what I am trying to find out how to do, pull the spindle? All the newer machinery that I work on, most push out the top for instance scmi shapers. This is a different machine for my fixing. Thank you.
I guess we're not speaking each other's language. on the top of the whole spindle is the threaded shaft portion that you put cutter heads on. If you notice there are flats for a wrench right at the bottom of this area. Those are to remove that portion of the shaft from the rest of the spindle. You should have a place lower on the whole shaft, perhaps below the pulley, to hold the shaft to unscrew the upper spindle. Once you do this you should be able to unbolt the slides from the front of the machine and pull the whole yoke out the front. A couple more pictures from the front and standing a couple feet further back would help me to explain this.
Dan
Dan
Thanks so much. I will try that tomorrow when I have some time. I knew it would be simple and as always I over think some things. Like I said all of my bearing replacing has consisted of pressing the whole spindle out of the cartridge while still in the machine. My dad got cancer after I bought the machine and passed away before we could start on the bearings. Thanks Dan, and everyone who replied.
If it's like my N44, there is a keyed cap that locks the spindle, preventing it from unscrewing. It has to be pried up and off to get the key out to unscrew the spindle.
