I recently found this forum as I am currently trying to restore an old Delta wood lathe and could use some advice at its current state. When I picked up the lathe, the motor worked and everything seemed intact except for the belts. I considered using link belts to replace these worn v-belts, but instead opted to dismantle the headstock. The existing bearings came off the spindle without too much effort after which I worked on finding replacement bearings. The boxes do not specify their dimensions, though I was told they have identical ID and OD, while because one is a bit thinner, I was given a couple dished washers.
My reservations arise after noticing how snug the new bearings fit on the spindle. I can find a tube or pipe that just fits over the spindle and hammer the then on, but am sure they would not come off without being destroyed with a puller I do not have. In the meantime, I tried putting the spindle in the freezer overnight to lessen it's diameter, but the bearings were no less tight. I am reluctant to hammer the new bearings on remembering how the old ones came off by hand. Here are some pictures of how the project currently stands.
