Results 1 to 12 of 12
    hd28vsb is offline Aluminum
    Jul 2005
    Ohio
    104
    Default OT : Anyone with plans to make a tenon cutter for log furniture ?
    A shot in the dark maybe but does anyone have prints or sketches on how to make a 60 degree tenon cutter or a radius tenon cutter ? I would like to make the wife some furniture but would like to do it on a budget. Just by looking at photos its hard to tell the I.D. dimensions of the cutter and how the blades attach. Thanks
    garyphansen is offline Titanium
    Feb 2004
    Traverse City, MI
    3,122
    I just chucked up the branches that I used to make these in my lathe and turned them down. Gary P. Hansen
    Feb 2004
    Traverse City, MI
    3,122
    Sorry I did not realize the photo was so big. I would resize them if I knew how. Gary P. Hansen
    Mud's Avatar
    Mud
    Mud is offline Diamond
    May 2002
    South Central PA
    10,891
    Quote Originally Posted by garyphansen View Post
    Gary - this makes it easy, and compresses them at the same time -
    http://www.rw-designer.com/picture-resize
    surplusjohn is offline Diamond
    Apr 2002
    Syracuse, NY USA
    9,280
    I have seen end cutters for this in catalogs, kind of an inside out router bit.
    wtrueman is offline Aluminum
    May 2007
    Vancouver Island
    249
    Default tenon cutter
    HD 28: The type of cutter you are wanting, I think, is on page 128 of the Lee Valley Cat. 2007/2008. A one inch one is listed at $16.50. Their no. is 1-800-267-8767. BTW, I have no affiliation with them but instead drool over their tools! Wayne.
    Gary Hart is offline Aluminum
    Dec 2004
    Vancouver, WA
    68
    Don't know if much help. Made a couple a year or two ago using some type of plastic that was is my supply box (Junk pile). Didn't have aluminum the right size to make them out of. The cutter was cut from an old planer blade. Only thing remember was placement of cutter was critical so that it cut the right amount for tenon to fit in back of cutter and clearance for chips to get out. These cutters were made for doing a fence and worked good using a heavy duty 1/2 hand held drill. Will try attach some clickable pictures............... gary
    bruto is offline Stainless
    Mar 2008
    Benson, Vermont
    1,183
    I have some of those Veritas (Lee Valley) tenon cutters, and they work very well, and cut with surprising ease. They're very nicely made (in Canada!). but they're certainly not cheap. A one inch tenon cutter of the sort being discussed here will set you back 89 bucks. I'm not sure what wtrueman saw, but $16.50 won't buy a replacement blade.
    Gary Hart's design is a little simpler than the Veritas, and might be easier to make. The Veritas has a curved blade which gives a nice rounded shoulder to the tenon, and finishes the diameter with a different part of the blade than the part that shaves the shoulder. This allows you to adjust the diameter to compensate for green wood, etc. I think the blade would be difficult to make well, so if I were intending to make one of these, I'd be inclined to buy a replacement blade and design the cutter around it.
    loggerhogger is online now Stainless
    Aug 2005
    Tacoma Washington
    1,202
    I think that Lee Valley Tools sells those.
    Mar 2008
    Benson, Vermont
    1,183
    Quote Originally Posted by loggerhogger View Post
    Veritas is Lee Valley's manufacturing subsidiary.
  11. #11
    Joe D Grinder is offline Titanium
    Jun 2005
    S.W. New Mexico
    2,391
    Let me see if I can do this with words instead of a sketch. To cut tennons on the end of logs, first drill a hole in the end of the log, say a 1/2" hole, about in the middle and running as close to paralell to the log as you can accomplish by hand. Next, bolt a bracket to the top of your table saw that has a 1/2" headless bolt sticking out of the side of it. If you want your tennons to be zero radius between the tennon and the body of the log, make the bolt crosswise to the blade. If you want a radius between the tennon and log, make the bolt run paralell to the blade.
    Mount a wobble dado blade on the table saw, set to full width. Adjust the height of the blade so that the distance from the edge of the teeth to the center of the bolt is the radius of the tennon you wish to make (you'll have to play with this). Slide the bolt into the hole in the log and start turning and feeding the wood into the blade. You can clean up when the bolt bottoms out in the hole.
    I have only done this with the bolt paralell to the blade and the saw running in a direction that tried to push the wood away from the blade, NOT suck it in, so if you change anything you may run the risk of grabbing and drama. Also,arrange the bracket in such a way that the bolt enters the wood before the blade touches the wood(obvious, but it had to be said).
    The other home grown way to do it is to mount the log between centers with a rounter running on two rails above the centers. Adjust the router height to get the size tennon you want and have someone rotate the log while you control the router. This way of doing it makes the two tennons always run in a straight line ( yeah, I know, more or less straight).
    I have seen both these setups in log furniture shops that did it for a living, but of course there are more proffesional set-ups out there. Method #1 gives a nice look to the wood if you include the radius between the tennon and the log, but also leaves your table saw with a couple of threaded holes in the top, which drives some folks nuts. I guess there has to be a way to clamp that bracket on there without the holes. Method #2 is more disagreeable in it's execution (hate router noise) but does make a zero radius joint between the tennon and log and lines the tennons up more nearly straight....Joe
  12. #12
    hdowner2004 is offline Plastic
    Jul 2012
    West Virginia, USA
    Gary Hart I was wondering if you still have the tenon cutters that are pictured above?
