dsergison
- Oct 23, 2003
- East Peoria, IL, USA
two part guestion:
#1 I have a teak dining table set. It's Danish modern or mid century or whatever popular term you want to call it. It has a lot of drink rings, small scratches etc... and I am wondering how to quickly refinish it's top. At least just the top surface of the table and maybe the chairs. I have HVLP spray gun. belt sander, long board, Da sanders etc... I am looking mostly for a coating recommendation for everyday hard use. My color is very light I do not believe I would be staining much if at all.
#2 I would love to make some more chairs, but that's a big project for me. The chairs are very simple designs, I would look to pattern trace the segments with a table router or shaper i have then I joint them. The chair sides unbolt. My question is how would be the best way to transfer the shape if I used my chair as a template? Of course the pattern master are all glued up. I think laying the chair side on a sheet of plywood and tracing it with a hand router and shank bearing to some 1/2" plywood thickness depth would give me a pattern I can reproduce on individual segments with a router and nose bearing. It would be a challenge using a hand router.
I could draw them and use a shop bot for a template. Maybe even to cut the profiles?
these are very similar to mine but mine have stretchers and straight trapezoidal finger joints.
http://furnishmevintage.com/wp-content/uploads/danish_teak_2.jpg
http://furnishmevintage.com/wp-content/uploads/vintage_teak_dining_chairs.jpg
Dan
Dan
